need help about sensor | on ElectriciansForums
Discuss need help about sensor in the Australia area at ElectriciansForums.net
A
ahmedalsh40
hello
i need help about sendor
i need sensor to measure density of coins
what is this sensor to do that ?
Hi,
Sorry the best I can do off the top of my head is: I guess this probably falls mainly in the place of the electronics lot. It could be an induction /magnetic thing and the density of the coin alters the susceptibility of the magnetic field which is measured.
RS components , Maplin, Franells are supplieres of components and may have some information in their catalogues / online sites.
Hope this is of some help,
Best wishes,
Rex
modern coin operated machines use a electromagnetic field that measures its thickness and metallic properties it then uses a cpu database to decide whether its real or fake what exactly is your purpose for the info.
Reply to need help about sensor in the Australia area at ElectriciansForums.net
That will only count when the alarm is active o/p said tamper. O/P doesn't seem to be in any rush to give more info, so I doubt anyone else will...
That will work fine as long as the Pirs use relay switching, some don't.
