Need help/advice, insure of what the problem is and think I’m being ripped off | Page 2 | on ElectriciansForums
Discuss Need help/advice, insure of what the problem is and think I’m being ripped off in the UK Electrical Forum area at ElectriciansForums.net
Wiltshire
hi all,
Today I had an electrician come around a rental property of mine and swap the faces of a few double sockets and light switches, he done this and everything was fine the sockets worked and light switches worked fine, as he was finishing up he was changing the lightbulb as he unscrewed the bulb the electric tripped and now every time I switch the consumer unit on the RCD trips so no power is going to the onsumner unit it is all a very old system and needs upgrading but he seemed stumped and clues less as of what has happened and why this problem had emerged and the property is now left with no lights or sockets, ill attach some photos of the set up, but as I can describe it the mains power goes to a rcd then from the rcd to an very old consumer unit with wire fuse, power is going in and back out of the rcd and into the consumer unit but when the consumer unit is then switched on the rcd trips
In the picture the top white metal box of the consumer unit
The guy I had to do the work is now explaining to me that because the switches are new and pull more power it has caused the cable to heat up and I need a complete re-wire, I just feel that I’m being ripped off.
[ElectriciansForums.net] Need help/advice, insure of what the problem is and think I’m being ripped off
He pulled out the fuse for the lighting circuit and tried switching it on and the rcd kept tripping then done the same with the socket circuit and the same again then finally pulled out all fuses and tried switching it on and yet again the rcd tripped again, has anyone here maybe a fix for his as the electric needs to be on tomorrow for some plasterers, I have been trying to do research but have no luck
RCDs trip when they sense an imbalance between the line and neutral conductors which are usually balanced. This imbalance is usually to earth.
If the RCD is still tripping with all fuses (line conductor) removed, this would suggest a fault between neutral and earth.
Look again at all the work done by the electrician today and the light fitting that appeared to cause the initial fault.
To catch a neutral with a faceplate screw is not uncommon when replacing accessories if not careful.
I'm not accusing anyone, so don't take it wrong, but to hear such rubbish from an 'qualified' electrician is a bit more unusual than to hear a load of bull from a landlord.
There seems to be an awful lot of knowing without understanding what exactly has gone on.
As others have said an Electrical Installation Condition Report would be recommended.
Looking at the cables I would imagine some are imperial (7/029) cables from the 1960s- ish. If that is the case you may find that the lighting circuit does not have a protective conductor (earth wire)
Only one way to find out, EICR, and be done with it, don't fight it, better to know now than later.
The snow is to blame Sam M4 corridor all messed up, sorry no help really, just trying to be a SA
I have done so and all cables don’t seem to be damaged, very curious to what has actually happened, beginning to think he has done some purposely in order to get himself more work
Maybe a complete coincidence that the RCD tripped whilst he was there but he should not have left leaving you with no power.
Are there any outside lights or garage supplies that water has gotten into. Have you tried unplugging all appliances, switching off the cooker switch, boiler spur and any other spurs. Then try to reset the RCD.
Reply to Need help/advice, insure of what the problem is and think I’m being ripped off in the UK Electrical Forum area at ElectriciansForums.net
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
Given that, it probably makes sense to TT the shed, unless you can be sure it doesn't act as an extraneous-conductive-part. (The SWA won't have...
