Speedypugh
Hi all,
I am new to all of this, so please excuse my lack of knowledge and experience?
I am not a qualified electrician, just a general enthusiast, and desperately need some help and advice on the following:
- I want to permanently install a webcam, that runs off a 9V adapter inside my PC monitor (i.e. drill a hole in the monitor and have the camera visible through the hole)
- I also want to somehow, run both camera and monitor using only one plug (if possible)
- so my question is, how do I go about wiring the adapter so that I can use the monitor's power supply, but also remain safe?
All answers and advice welcome.
Thanks so much in advance,
Gareth
Hi all,
Gareth
I would suggest you do not attempt to do what you are thinking unless you are happy to work in among high voltages that could give a nasty shock.
Need help and advice with rewire
Speedypugh,
Golden_Boy,
