Need help, setting horstmann economy 7 - it's just not working | on ElectriciansForums
Discuss Need help, setting horstmann economy 7 - it's just not working in the UK Electrical Forum area at ElectriciansForums.net
X
Xto
Hi guys,
First thank you for reading and helping out.
Ok I got the above water timer, since last week it's just doesn't seem to be working.
First off i set the time as per current time, i set the time as "summer." but it just doesn't seem to heating up the water and importantly it doesn't seem to maintain the hot water throughout the day.
What am I doing wrong?
the timer dial is set to current time based on 24 hr clock, there are two groves between the times of 24to3am and 5am to 8am. But it only clicks when the from 5 am.
How do iI set it to heat up as before, through out the day?
whennthe water timer light goes red does this mean water is heating up? ( non boost light)
All help will be apperciated
The ON time is set from inside and should be for a couple of hours around 4 /5/ 6 am, then OFF before 07.30, or whatever your local E7 time finishes.
To use it in the day you need to turn the Boost, but it's for the length of time indicated only.
If you need hot water all day you will have to keep resetting the boost timer.
The Timed (non boost) red indicator will show when the timeswitch is active and heater is ON, assuming the ON / TIMED switch is set to TIMED.
It may be that the immersion heater has failed or the over temperature thermostat has tripped.
Thanks snow head gor your input. Is there a way to maintain the temperature ? As said there are two groves but the water timer red light only comes on when the summer time mark between 5 and 8 and nothing happens during 24 hr and 3 am
The timer is designed to use E7 overnight, with additional boost in the day if needed.
Not to be on all day.
Unless you need water between 24 and 3, there's no point having it set for then, On at 05.00 and OFF at 08.00 is O.K.
The tank will only take about an hour to warm up if it's normal sized.
Did this previously work and has suddenly stopped, or has something else changed, have you had a new meter fitted recently?
The timer you have in pace at the moment is specifically designed only to work whilst there is cheap rate electricity overnight on economy seven.
The likely time it would be on are somewhere in the region of 01:00 to 07:00, though there are two different settings on the timer for the first time E7 is on (23:00 to 24:00 ish) and the last time E7 is on (02:00 - 07:00 ish) , the times vary with region and supplier.
Your timer may be set not to come on for the first period and only come on for the second period, this would however mean it was heating for three hours which should be enough to heat the water in the tank sufficiently for the morning.
If you are finding that the heater is working as above but it is not keeping the water warm enough during the day then either you have a poorly insulated tank, or the heater element has failed, or you are having a bath in the morning and draining all the heated water from the tank and leaving nothing for later in the day.
Because the heater is not designed to heat the water during the day the only way to keep the water hot automatically is to buy a suitable immersion heater timer and set it to heat the water when you want it to do so.
However if you run the immersion during the day and are on economy seven then you will find it expensive.
Guys really need to get hot water going, pls can you advise I'm gona manually change dial time to trigger timed emmersion. Pls advise what hours does the water hear up in?
These are the installation instructions for the timer
View attachment E7Q-InstallationInstructions.pdf
If you read the "adjusting the off peak time period" section at the end and adjust the rotary dials inside to be on to the maximum you will find that you are paying a lot for the electricity use but you may be able to get enough hot water.
Remember that you cannot get this timer to operate all day.
And if your immersion heater element is gone then this will not work.
Reply to Need help, setting horstmann economy 7 - it's just not working in the UK Electrical Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
Part III:). I think I have clarity-having spoken to my electrician who installed my heaters, he said that the part of my fuseboard that is...
2 3 4
