Is there anything out there to help me get my head round control panels and control circuits. I was stuck at a job trying to get a metal barrel press to work automatically. Press start button, press comes down, squashes everything, pressure switch activates and it comes back up and hits the limit switch to stop the cycle. Best I could do was to have it working without even pressing a button but it would go up and down at will, unless the door was open, limit switch through the e-stop.
Had to leave as a manual job, hold start button in, install new limit switch at bottom of press so they cant hold the button in for the pressure to keep building. Then another button to bring the press up to hit the top limit switch and stop there. Pump would still run if holding the button in but if at either limit it wouldnt move, unless in the opposite direction.
Im sure this is a basic circuit with a relay but Ive never built a panel before and would like to learn a lot more. This hurt my head and frustrated me and I dont fancy going through it anymore, I need more knowledge.
