Need help with identifying circuit for socket (newbie) | Page 2 | on ElectriciansForums
Discuss Need help with identifying circuit for socket (newbie) in the UK Electrical Forum area at ElectriciansForums.net
G
Gareth Luck
hi all
Apologies that this sounds stupid to most. I'm not a qualified electrician, just a diy'er with an interest in electronics.
I'm renovating my kitchen at present, I just removed a double socket with the plan of re-locating it. However i cant work this one out, despite reading my 'Collins Complete DIY' book and searching online lol
When i removed the socket i disconnected all cables. It was fed via 2 2.5mm cables, one coming in vertically, the other looking like it goes out horizontally towards the other double socket on the same wall. However even when disconnected and taped off, all other sockets still work in the kitchen? I thought this would be part of a ring main? Can it be a spur with 2 cables?
This is a quick birdseye 'diagram' of the kitchen and a close up drawing of how the socket is fed.
[ElectriciansForums.net] Need help with identifying circuit for socket (newbie)
Thankfully the bother in law is a qualified and registered electrician so he's doing most with my eager eyes watching. Unfortunately he's not around right now and my mind is playing havoc with trying to work it out!
cheers for any help in advance
As above, you really should connect them back together as you have split your ring in two (arf arf) and the protective device is now most likely over rated.
Still it is a shame you can't ask without being pounced on.
Better off asking first before 'gung hoing'. It's only domestic though, I suppose. :willy_nilly:
hi all
hit the road divvy...
hi all
If you continue to call him ' bother in law ' its hardly surprising he is not around, however I would suggest you give him an urgent call and apologise for meddling into something you clearly do not understand, and this time try calling him something that fits his status ( if he is qualified ) like Sir or God.:innocent:
Reply to Need help with identifying circuit for socket (newbie) in the UK Electrical Forum area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
