dredski
i have a job to add an additional socket in a kitchen and i know i need to complete a minor works certificate but what test or tests will i have to perform i have a fluke 1652 tester. please help
Discuss Need help with minor works cert in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
can the test all be done at the socket or will i have to go to the board
yes i am a new electrician but i have only filled in a new installation certification and i kno how to do all the tests..if u read my thread carefully i was asking what needed to be tested for a socket upgrade as i have not done a minor works cert beforeDredski are you an electrician. because you have a tester but no idea how to test the circuit. where did you get the minor works cert.
Because if you cant test then fill out the cert incorrectly and there is a problem , u will be liable
oooohh someones tiredoh diddums at least he asked and didnt 'have a go' without asking. good on him for asking and with replies like ^^^^^^ no help at all he'll prob just take a flyer now. Hope all who unhelpfully replied realise that they are making the situation worse just to make themselves feel a bit bigger. Bet their mrs wears the trousers at home ffs
I just can't believe this question has been asked from someone who is an electrician
Reply to Need help with minor works cert in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
