OP
David.
you don,t state the distance from the 3phase db to your new cons.unit,personally i would,nt use less than 10/16mm plus additional earth.
yours benji
approx 5 meters at the most.
Discuss Need quick help with IT room in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
yours benji
the 20amp sub-main will deffo be undersized
yeah i agree now that its been mentioned computers use a lot more power than what i originally thought. I had based the 20A on 10 machines running 300W each.
TBH i think im going to just run a 32A ring main. Its all in trunking anyway and it saves fussing about
However im still wishing to learn and understand so if I were to run a submain in 6mm fed by a 32A MCB to a small CU with 3x 16A RCBO type B would that have been OK??
Reply to Need quick help with IT room in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
