N
netsniperthe1st
First of all can I apologise if this is in the wrong forum
I have a little problem? I bought a house in Russe Bulgaria which was recently built but looking at the wiring it doesn't seem to have an earth well not as we know it in the uk? how they do it there is the take a small piece of wire from the neutral and link it into the earth terminal so in affect the neutral became the earth as well, what I want to know is how safe is this and is there anything I can do to make it safer? the fuse board has those automatic things that switch off when a bulb goes or there is some other problem, the voltage is around 230 and there is 2 separate power cables that come to the house overhead, any advice would be much appreciated
Thank you
Thank you
