need some help | on ElectriciansForums
Discuss need some help in the Australia area at ElectriciansForums.net
snakeface5
I have just been given some work on a large residential home after it failed its five year inspection some of the work needed is replacement of old cables.Thats understanderble for some of it old alli cables wit no earth and very falling to peices on the lights needs replacing..But some of the sockets are also being fed with alli cable but its got an earth and is in good condition does this still need to be replaced on inspection it says new regs says it does i done 17th edition and looked in my book but couldn find it any where?Also in this place there is about fifty porcelin sinks with no cross bonding i checked at the water mains and the boiler and all pipes are cross bonded and have a main earth supplied as well so do i still need to cross bond every sink in the installation also.Allso this might sound like a no brainer but when i checked all the fuseboards there is no rcd protection at all on sockets and the whole kitchen area but it has not been highlighted in work needed to be done is there any reason for this.
Im not trying to be rude but any works under taken must comply to 17th regardless of what failed previously on the inspection, remember you or building control need to sign off the works.
If your not sure then dont do the work.........You will be liable if any thing happens
Remember it does not matter what some one else found that was wrong but that the work you do that must be right and the install altered must comply to CURRENT regs, which includes correct certs etc
Ash
commercial installations dont normally have r.c.d's on the c.u's especially 1's that fail there inspection......id be looking at a rewire becuase when the next 5 year inspection is due it will fail on sumin else...
Reply to need some help in the Australia area at ElectriciansForums.net
Great, then I am a bit bemused why you posted your original question. You need to stop doing any work that you cannot properly test, safety is...
  • Poll
I died and fell off the planet the last 6 weeks. Business partner has been away on courses and holiday, and I was left looking after the children...
