need to install 3 sky points in a house | on ElectriciansForums
Discuss need to install 3 sky points in a house in the Freeview and Terrestrial TV Forum area at ElectriciansForums.net
C
charlalberts
HI,
I was wondering if anyone could give me advice on installing 3 sky points in a domestic house.
Would i just need to run shotgun cable from the main sky point to the 3 individual rooms that need the points?
Any help would be most appreciated
Shotgun cable from dish to each point wold be required for Sky+.
You can run a single satellite cable for standard sky / satalite boxes. The dish will need to have an LNB with enought outlets for each cable.
As above ^^^^
The tuning process for a channel frequency involves frequency switching the LNB band (hi/lo). So you need an outlet for each box direct from the LNB. As said two outlets at each point if it's sky+
Reply to need to install 3 sky points in a house in the Freeview and Terrestrial TV Forum area at ElectriciansForums.net
Think all has been covered already, but echo-ing the above if I was getting my DB swapped and had a 3 phase head, I would put a little TPN board...
M
Aqualisa electric shower, mains water entry point blanking plug Hello, Im looking for help in tracking down a replacement part for an Aqualisa...
Marty
M
