Need to replace mk 100ma rcd (6160) with 30ma one | on ElectriciansForums
Discuss Need to replace mk 100ma rcd (6160) with 30ma one in the UK Electrical Forum area at ElectriciansForums.net
Reply to Need to replace mk 100ma rcd (6160) with 30ma one in the UK Electrical Forum area at ElectriciansForums.net
Good point, I was assuming an up-front RCD is for fault protection within DB, etc, and to cover for a failed RCBO for fault conditions, not as...
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
