Currently reading:
Neff hob with a plug - can it be hard wired?
Discuss Neff hob with a plug - can it be hard wired? in the Electrical Appliances Forum area at ElectriciansForums.net
Hello,
I had a rewire in my kitchen extension weeks ago and the electrician left a spurred hard wire for the hob in the right place before my kitchen was fitted.
The kitchen is now fitted, apart from a some appliances, and it seems my Neff induction hob has a plug socket... I just assumed it would have been a wired connection and so did everyone who quoted for the job when discussing.
Can the plug be removed and the hob connected direct to the hard wire?
How easy is it for an electrician to change the wired point into a power socket?
Thanks,
Scott
I would definitely go with changing the outlet to a single socket as hard wiring a plug appliance to a (presumably) 32A circuit can cause a few problems. With a socket and plug scenario at least the the fuse drops the amperage to (at least) 13A.
While talking about wiring of hobs and by extension ovens if a scenario occurs whereby a hob is hardwired while the oven has a plug then the best option would be to install a dual backbox (surface is OK space permitting) with an outlet on one side (for the hob in above example) and a single socket on the other side (for oven). Amongst others things need to also ensure the cable is of adequate size for the combined load too. Hope this also helps.
Huseyin
Cutting off the plug 'top' will not invalidate the manufactures warranty, in most cases. One should verify with said manufacturer to see if it does; in my experience of asking such a question, most don't care.
Edit; their are some that specify their original supply leads must be used. But thats typically, when they have a moulded female socket that is inserted into the appliance.
That's also perfectly safe, the only (slight) issue with that is cutting moulded plugs off usually violates the warranty. The (long) way around that is to contact manufacturer / distributer and request the appliance without a plug. Thanks.
Ahh that old myth, the warranty isn't violated but it does cause issues for safe isolation if a manufacturers warranty repair is needed because the manufacturers safe isolation procedure is remove plug from socket if connected to a spur then they usually require it to be disconnected / reconnected by an electrician
Turn off the FCU & isolate, then cut the flex :)
I’m about to install a couple of Neff ovens and it interesting that the supply leads now consist of a socket into the oven on a 2.5 flex with bare conductors at the other end.
Interesting. Not seen one of those sockets on a job before.
But anyways, of course, the hob will be hardwired into an appropriate connection plate, minimum breaker size 16A.
Those connections are for an oven and microwave combo oven. Not had a close look at the hob yet but it’s a 7.4KW induction hob.
Are the manufacturers always correct?
The heater panels I installed recently were of 2 sizes...by that I mean 350W and 700W respectively.
The 350W ones came with a cable and no plug, the 700W ones had a moulded on plug.
I put plugs on the small ones, with 3A fuses.
The big ones had 13A fuses installed in the plugs. I substituted 5A.
During a telephone call with the suppliers I mentioned this...they said I'd probably just want to hard-wire the whole lot anyway, and wouldn't comment on fuse size.
Anyway, it is clear that they had no issue with removing factory-fitted plugs.
Reply to Neff hob with a plug - can it be hard wired? in the Electrical Appliances Forum area at ElectriciansForums.net
