Nest Protect Smoke Alarm Install Help | on ElectriciansForums
Discuss Nest Protect Smoke Alarm Install Help in the DIY Electrical Advice area at ElectriciansForums.net
Glasgow
Hello
I recently purchased a nest smart smoke alarm. I currently have 2 mains linked smoke alarms (one upstairs and one down). My plan was to replace the existing with the Nest versions.
The instructions seemed simple enough but when I have removed my existing alarm downstairs I ran into my first problem. It seems there are 3 sets of cable going into the existing terminal block (earth, live, neutral x3) and one interconnect cable. I was hoping someone could advise how this should be wired up? As the Nest instructions only describe if you have 2 of each connector and the terminal blocks they provide in the box only have space for 3 connections including to the alarm itself, which means there is an extra set of connections.
I believe current connection is taken from the lighting circuit if that helps. Attached picture of current wiring.
any help would be greatly appreciated.
  • [ElectriciansForums.net] Nest Protect Smoke Alarm Install Help
Looks like a looped feed in, looped feed out, then a 3 core linking this detector to the next. (Live, neutral and interconnect)
if there isn’t room in the new detector, the only option is a separate joint box up in the ceiling and bring the 3 core down.
Reply to Nest Protect Smoke Alarm Install Help in the DIY Electrical Advice area at ElectriciansForums.net
I think it was too early yes I meant 3 not 2, but great I'll give that a whirl and thanks.
The previous bell box worked fine. I think it was just lacking the added security of anti tamper. Can this one be wired the same?
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
