Nest Thermostat 3rd gen compatible | on ElectriciansForums
Discuss Nest Thermostat 3rd gen compatible in the Central Heating Systems area at ElectriciansForums.net
Glasgow
Hi all
Hope everyone is having a good New Years Eve!
I have a quick question which I’m hoping you may be able to help with. I’m trying to determine whether or not the Nest 3rd gen thermostat is compatible with the current wiring but the online tool hasn’t been much help.
I have a Danfoss TP9000 wired thermostat and have taken a picture of the wiring below. Hard to tell from the picture but black wire is going into 3.
[ElectriciansForums.net] Nest Thermostat 3rd gen compatible
Any help would be greatly appreciated.
Hi, are you just asking to see if this is worth you persueing using a Nest installer or are you planning on doing this yourself?
From what I can see it should work, (with a little bit of modification) with the wiring connected to L&N and 3&4, but the wiring connected to terminals 5&6 needs to be investigated to see what it is connected to - possibly remote frost stat? - this may not work with the Nest system.
Another point - where are the earths terminated?
If you are not an electrician, I would suggest you get one in to install this for you.
5 and 6 are for a remote sensor, 3 and 4 are for CH ON and HW ON. The nest heatlink could be installed where the TP9000 is and the nest thermostat installed where your remote sensor is.
Thanks for the quick response guys
Definitely not planning to do the install myself but just wanted to know if it was compatible before I purchase the thermostat and get someone to install it.
I have a Danfoss TS2 remote sensor too if that helps in determining what 5 and 6 are connected to.
Yeah your set up is nice and easy.
Reply to Nest Thermostat 3rd gen compatible in the Central Heating Systems area at ElectriciansForums.net
The point is that you set up a schedule of what temperature you want at what time and the nest brings the heating on at the right time to achieve...
davesparks
Ah OK, that makes sense. Thank you Avo.
