Nest thermostat compatible wiring
The nest heat link could replace the programmer but the cable that goes to the thermostat will be at the wiring centre so won't be able to be connected to the heat link. If the programmer and switched fused spur is next to the boiler then you may not have a permanent live at the wiring centre as it's not needed being a Y-plan. An electrician who knows heating will be able make it work.
The thermostat is battery powered, the receiver that will replace the current thermostat is 230v. You need a neutral and live for it to work....this will need testing and configuring by someone competent.
The nest thermostat is not battery powered, it is either powered by a plug in adaptor or a 12V supply from the heatlink.
Oh I see. I thought that the Heat link replaced the programmer. I have a Honeywell programmer next to the boiler, which has an isolation switch next to it. My boiler is 5 years old.
The nest system replaces both the thermostat and the programmer.
However the heatlink will probably not go in the same location that the programmer is in now, usually it will go next to the wiring centre in the airing cupboard.
Your thermostat will almost certainly be 230V currently, but the installer will connect this cable to the 12V terminals of the heatlink for the nest thermostat.
Sounds like I will be ok then , there is room in the airing cupboard for the heat link.
