Neutral earth fault | Page 2 | on ElectriciansForums
Discuss Neutral earth fault in the UK Electrical Forum area at ElectriciansForums.net
newcastle
I swapped a db on a job yesterday and there is a fault on the heating circuit and i just cant find it in the most disgusting house you have ever seen what is the deal with putting it on the non rcd side? can i do it
James
In answer to your question its a big NO.
The regs do allow you to place circuits on un RCD protected ways in certain circumstances but never when a fault exists on the circuit.
I am affraid you will have to trace the circuit and fault or leave it disconnected and explain to the customer the reasons why!
Just wondering if you are asking such a basic question should you be replacing a db
the route of the cables alone start to answer that one for you.
Suck it up and don`t breathe through your nose. Get those circuits tested, find and fix the fault. Issue cert, get paid-premium charge for the scummy conditions.
Learn from it and move on. Just when you think that you have been in hell, along comes hell 2.
I worked in a property once were the fella new about a dead rat in the bottom of his boiler cupboard and he just let it de-compose and rot away
Reply to Neutral earth fault in the UK Electrical Forum area at ElectriciansForums.net
Exactly. I was going to ask on the earthing once he clears this boiler fault (suspect on internal component). OP mentions oil boiler but makes no...
Update. Went back today as it was popping the other RCD post move, again intermittently with no real pattern. Typically overnight but not every...
