Neutral Fault | on ElectriciansForums
Discuss Neutral Fault in the UK Electrical Forum area at ElectriciansForums.net
L
Lee_Dicks
Hi guys and girls
I have had a phone call from a friend saying that the socket under the kitchen counter for there washing machine is not working.
I tried a socket tester in it and there is a neutral fault. IRd the circuit and tested all the other sockets. All's fine.
The socket is controlled by an FCU located above the counter the fault is between here and the socket beneath the worktop. The FCU controls the socket and an outside socket. I have tried them individually and there is a fault on BOTH sockets.
I am still in training and there electrician is on holiday any help will be greatly appreciated.
As above either neutral as come loose on loadside or fcu is faulty on neutral outfeed
Ok I will swap it for one of the other ones in the kitchen and try again.
Thank you all for your help
By the way while I have you on here can anyone tell me what they think of the 2365 parts one and 2?
IR for kitchen circuit was above 200Mohms (tested with fuses from fcu removed) so I'm a bit stuck there.
Volt tested as well socket next to fcu was at 243V but at socket in question was at about 12V (forgot to mention that earlier) a socket tester showed a neutral fault (checked it on all sockets in kitchen and front room all working)
Reply to Neutral Fault in the UK Electrical Forum area at ElectriciansForums.net
2 3
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
