Neutral insulation fault strange! | on ElectriciansForums
Discuss Neutral insulation fault strange! in the Australia area at ElectriciansForums.net
Hi guys got a IR fault, basically there is a low IR reading on the upstairs sockets Live to neutral nothing strange there, but the rcd will only trip if the lights are switched on. so this is what happens i disconnect the lights and the upstairs sockets work rcd does not trip, then connect the lights still ok then flick any light switch and rcd trips. Disconnect the upstairs socket neutrals and everthing else works fine. Iam going to split the ring to find the fault but why would it affect the lights, is it an earth fault? any ideas guys? cheers i know you will want questions answering so ill do my best.
I found it at the testing stage i didnt pick up on it before because its a old empty house and all the power was on when i got there. I first found the fault when i turned of the the power at the main RCD switch, then i went round making sure nothing was live. then it wouldnt switch back on. so i then started testing all the circuits.
So you were called in because of this? or did you do something and this was a result?
I was thinking a diy borrowed neutral at first causing the problem and the owner thought he had best get someone in who knew what they were doing but I'm guessing the old dreaded borrowed neutral crossed your mind too
I was told nothing just instructed by the estate agents to do a PIR on the property, and had no idea of any faults. its not a split board though there is only one rcd main switch.
work out your circuits and do you r1 and r2 and rn tests on sockets if t&e should be nearly all be same result, then do R1+R2 on lighting circuits.. see if reveals you hidden secret how low is low on IR result. could there be a socket in loft and coming off it for lighting maybe just say 123 here i come gl
I take it the upstairs sockets and lights are not on the same rcd. Is your low IR reading 0 MΩ - doing a continuity test might give you a bit more info, eg a neon or a lamp. suspect a neutral interconnection between the circuits.
Sounds to me that you have a borrowed neutral from a socket to a light fitting. Try isolating socket circuit and remove socket neutrals from bar in cu and connect in a choc block. Now try your lights to see if they all work. If you find any that don't work then reconnect socket neutrals and recheck lights. If the lights then work you have a borrowed neutral.
but all circuits are on 1 RCD. i suspect there's a fault on a switched live somewhere, only shows up when switches are operated. could be a trapped conductor behind a switch.
Sounds an interesting one especially as
Reckon the lighting needs more investigation and checking against the up sockets for continuity and IR. If they are on the same rcd it must be an earth fault.
Reply to Neutral insulation fault strange! in the Australia area at ElectriciansForums.net
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
You too? I thought I was in a unique position:anguished::coldsweat:
