P
powervan
Hi whats the situation on following!
went to wire a bathroom today in old terraced property all looked good new board (last 6 months) full niceic member! certificates not to hand YET! looked in loft to find V I R cables! works out from board new cables run 2 mtrs into joint boxes picking up old cables! as it happens its not a problem for me as found a pvc 6mm left in loft and other end just outside the board
)) so can work my stuff from this BUT i would only ever connect to old cable if we were doing a rewire very shortly after!! is this a Good Practice issue or is there a reg that said THOUT SHALL NOT CONNECT TO VIR even if it tests ok?? lighting hasnt cpc but thats not the issue as this has label on the board! diff subject the plumber used a junior hacksaw to cut through a live vir cable that just had no jb on end ASSUMING it was dead( he wont do it again
