New build compliance vs renovation compliance | Page 2 | on ElectriciansForums
Discuss New build compliance vs renovation compliance in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Rolyberkin. None of the works have been tested as far (we were waiting until completion) All of the wiring is still visible in one of the two houses. The other is post-plaster. But can be accessed by lifting the floor boards in the right places and cutting out the plasterboard (not desirable, but possible) We’ve got one house fully open and everything is visible. The plastered house is a carbon copy of the one in which the wiring is still exposed. So this indicates the methods used. Any thoughts going forward?
I must admit I was being facetious!:) I would recommend you speak to your BCO and discuss your situation and ask their advice (they like that!) most councils will allow you to commission an EICR at your cost and pay an additional regularisation of works charge to comply with building regs.
I bet you won't have too much trouble, even if it means extra cost to get the local BCO to accept an EICR in place of an EIC. It's wrong and it winds me up, but thats the way it will probably go.
Out of interest do you have a 'new build insurer' such as NHBC? If it were to be NHBC, those guys are IMO very very picky. They won't like an EICR at all.
surely a new build is subject to planning permission and inspected at stages by BC. this should include the electrical installation.
I agree with telectrix; the build will have gone through a planning process & therefore the electrical installation will not need its own notification to LBC. Just a certificate as appropriate under BS7671.
Reply to New build compliance vs renovation compliance in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You made the mistakes of a) asking the wrong question, and b) asking it at all. If you ask them, then of course they'll gold plate their...
how long have you had the oven? Could be that the heating element has blown. Which happens after a long period. Is everything ok on the...
Cbelectrics
C
