New build CU entry and posistion | Page 2 | on ElectriciansForums
Discuss New build CU entry and posistion in the UK Electrical Forum area at ElectriciansForums.net
magnoliafan89
Hereford
Visited a new build today with my spark to see his mate and having a look around came across this in the utility room loft.
Asides the horrendous entry i was under the impression from college that regs state a cu has now got to be made accessible and the switches of the breakers between 1350 and 1450..or is there exceptions to this?
[ElectriciansForums.net] New build CU entry and posistion
thats nothing, ive been working in a building where windows are now jammed closed, some windows have smashed, doors wont open or close properly, cracks all over the walls, they obviously thought hiring a structural engineer wasnt worth the money
these are 4/5 floor flats, about 7 blocks altogether and all of them have problems
the electrical side of these buildings are actually ok though lol
HELD TOGETHER BY CABLE NO DOUBT.
Ive only ever taken the incoming through a gland and never had any other circuits go through the same entry with them...not that i could. But as this is what ive only ever been shown whats everyone elses opinions is it ok to send them all through the same entry or is it best to seperate the incoming with circuits?
I can only think that this is not finished yet and an intended 100x 50mm trunking enclosure is planned to tidy it up.
If that’s not the case, then it’s a pretty poor show. At least a grommet strip should be evident!
We can only speculate!
Wonder how long the tails are? And why not use 2 round knock outs and grommets? - would've been quicker too.
So 1350-1450mm board height, just because it’s not in BS7671, we still have to mount it there right? Or are you allowed to place them high out of reach etc
Think it depends on the context of the job and what is expected plus, as mentioned above, it is a recommendation and should be treated as such.
more down to what the building inspector will accept . if he insists on fitting a CU for dwarfs, then snow white and the 7 can live there.
Reply to New build CU entry and posistion in the UK Electrical Forum area at ElectriciansForums.net
