new build outside light | on ElectriciansForums
Discuss new build outside light in the UK Electrical Forum area at ElectriciansForums.net
GPack
Hello, What is the correct way of running the cable for an outside light as per regulations and good practice?
I have a timber frame building with a 50mm cavity and outer leaf brick work. Is it okay to run the cable from the loft, down the cavity and through a hole in the brick work? or could you just drill a hole straight through the brick, cavity breather membrane then ply of timber frame, then up to the loft space?
Thanks for your help.
with over 100posts on an electricians website, i would of thought you'd know the answer to this question.
The idea of running cables in cavity walls absolutley stinks - see it now and again and can't stand it. I'd hate to think that a proffesional electrician would do it. Bad, bad practice IMO.
poor practice, yes. but is it not worse to compromise the membrane? i'm not sure of that, but was once told by a BI that it was verboten.
check with your house builder if it's OK to pierce the membrane. if not, then it's up to the attic on the inside and surface on outside. use black flex on the outside.
We have been doing an estate of timber-framed houses and have been told that we can breach the membrane to get outside, but have to make good with silicone sealant to restore the air-tightness, which seems reasonable.
a good sqirt of expanding foam should do the trick. when it oozes out from the cavity through air bricks, you know you've put enough in.oh, poo. thought this was a builders' forum.
I do loads of timber frame, and as it seems to be the next generations method of choice then get used to it!
It's better practice to have first fixed it right to start with and run your cable in behind the vapour barrier, but either way it's just the normal downwards drilled hole straight through whatever is in the way and out the other side, insert cable, insert some foam around either end to reseal. Job done. Would normally take me about a minute. Remember to allow for screed and render depth on the outside wall so that where you've brought the cable through isn't directly behind where you'll need to second fix the light and drill through your own cable!
All i know is breaking the vapour membrane without positive resealing is a complete No, No!!
I'd personally never buy a wood framed house, or build an extension with this system for love nor money!! lol!!
Well, both architects and environmentalists seem to like it for a number of reasons; U values, sustainability, carbon output.....oh, sorry, I forgot: You're doing projects in China.
Nowt wrong with timber frame as long as you can accept that in the same way seeing a nice vintage car still running about on the highways and knowing it won't be happening with the car you drive.A flood,small fire or passage of enough time and it's time to build something new.It's why i collect anvils for a hobby...longevity rules:clown:
Reply to new build outside light in the UK Electrical Forum area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
