Hello, What is the correct way of running the cable for an outside light as per regulations and good practice?
I have a timber frame building with a 50mm cavity and outer leaf brick work. Is it okay to run the cable from the loft, down the cavity and through a hole in the brick work? or could you just drill a hole straight through the brick, cavity breather membrane then ply of timber frame, then up to the loft space?
Thanks for your help.
