This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
To keep people like you happy as you do seem to use the negatives quite regularly.
I doubt you've done proper research, but if and when I use them, I do quote the post and give a reason ....
I think they need to be removed.....
Why don't the plumbers have them then?
I can’t answer that question as I didn’t set up the forum software. If you feel the 3 ratings in question shouldn’t be there then don’t use them.
I've given you a dumb because these can be included or excluded - Dan could do this ................
Do you realise how ridiculous that sounds, do you honestly expect Dan to remove them just because you don't like them. As Sintra has already pointed out , if you don't like them then don't use them.
I disagree with you there mate.
If Old, Bad Spelling and Dumb could be removed then it would be a good thing.
See my post #55 for why.
I'm using the phone mate so can't see post numbers.
My point is that a member cannot hand out 79 Dumb ratings and then ask for the ratings to be removed because he got a couple, you must be aware of the saying.. Don't dish it out if you can't take it.
Tbh I’ve looked through at lot of members and what ratings they’ve given and those 3 are seldom used. The one person that sticks out that uses these 3 the most plus the disagree rating is our friend @Murdoch
@GMES @Sintra . I'm just talking from my point of view mates. I rarely give out bad ratings. As in the post above to @GMES , rather than giving a Disagree I just posted that I disagree and explained why.
Yes I have give out a few jut they are rare.
@GMES, the last 3 ratings (Old, Bad Spellings & Dumb) should be scrapped. Nothing constructive comes from them.
If I post something and someone thinks is Dumb then I'd prefer them to explain why. That way, if I'm being dumb, I will learn from it.... I learn nothing from someone just hitting the Dumb rating..
@Spoon I’m not disagreeing with you all that I’m trying to get over to @Murdoch is that he and one other appear to be the biggest users of these 3 ratings. If they did get removed then I have an inkling that they would use the disagree option instead. Personally I don’t use the negative ratings regularly and would prefer to critique in a reply.
In fairness to @Murdoch, there are a few low content members out there, that give 'dumbs' out, and very little else. I recall one guy give me a dumb for a very innocuous comment I made, which I challenged and he made no reply. Not surprising when he only posted about four times in 5 years!
Didcot, oxfordshire
New consumer unit and partial rewire in Didcot, Oxfordshire
Electrician Jobs
Electricians Jobs
Polibon,
Midwest,
