New consumer unit, builder says upgrade supply | Page 6 | on ElectriciansForums
Discuss New consumer unit, builder says upgrade supply in the UK Electrical Forum area at ElectriciansForums.net
London
Hi
As part of a loft conversion to my 2 (now 3) floor flat in a Victorian Terraced house I have added about a dozen 2-gang sockets, a shaving socket, and about 16 downlights to my new floor, plus swapping four pendant lights for 16 downlights in the floor below.
An electrician was installing a new consumer unit today and then I got a call from the head builder who is not onsite. He told me the electrician is concerned that the main service feed coming into the fuse/meter is only 10mm across. The electrician has apparently wired and tested everything (even though he's left the ground floor lights not working) but says we can't turn on the power in the loft as he is not confident the consumer unit will not burn out or the RCDs will be constantly tripping as the mains service cable is too thin.
The head builder told me I will probably have to upgrade my supply. He started advising me to call The National Grid (I think he means UK power networks).
I checked the main feed wire and by my measurements it looks around 12mm across. My builder was saying it should be more like 35 mm across and they'd never seen this before.
I apologise for the lack of detail but that's literally all the information I have aside from two photos of the set-up which are attached.
The reason I am posting is this all seems very light on detail. For instance I would expect a bit more calculation and maybe some figures to justify why we need to shell out many thousands potentially to upgrade the supply. The same amount of people will be living in the house, there are just likely to be a few more lights on and maybe an extra device plugged in.
Could anyone offer any advice about this? Should I just accept it, should I ask UK Power Networks about it, or should I be asking for more detail about how he came to this conclusion (and if so, what?)? Do the photos suggest what we have is obviously wrong? Any pointers would be much appreciated
cheers,
Pariah66
The service cable, (micc) needs reworking, fuse drawn by us at origin. Steel box with pyro terminated into it, no bango reqd, brass gland, 16mmsq earth from box into earth bar. Sit 100 amp existing series 7 on top of new box. 25mmsq brown and blue from cut out and meter from meter guys. Full test on con's wiring, and remedial.
Those are very bold statements and assumptions based on looking at a photo ......
Interesting comment without being able to see under the cover!
From what I've seen they have 100A RCDs other than I have no idea.
Not sure how a 17th unpopulated board differs from an 18th unpopulated board.
I've no idea how you can tell from that picture...
Awaiting enlightenment also....
I'm sure I read somewhere that the lid had to be hinged from the top, as in self closing, to comply with the regs pertaining to the containment of fire. Come to think of it, that info may have been getting banded about around amendment 3 time.
I also thought that.
My conclusion; I think we have found the sparky that done the job :)
Can't say it'd be worth my while to travel to the other end of the country to throw that on the wall.
You can tell all this from a photo? How can you tell what fuse is inside the 100A rated fuse carrier?
Even though the op said it was old wiring that doesn’t mean that they shouldn’t be glanded going into new CU , obv his builder has just done a bit of smooth talking, defo worth getting tested independently,
Gulls start their racket around 4.30 at this time of year. They are about the only negative from living where I do. A few years ago I would often be up around dawn, rig my board and have an hour or two windsurfing before I started the day.
Over here in the Isle of Man I installed a bird deterrent system for a development close to the cliffs of nesting gulls.
Part of the planning conditions apparently..
It came with loads of settings for different types of birds..
The one that seemed to work best was the noise of a hawk..
My favourite was the distressed gull sound, the gulls went crazy and swarmed the whole area, it was like a scene out of Hitchcock’s Birds.
Police came down and it got a mention on the radio.. I never mentioned a thing, just shrugged my shoulders and mingled in the crowd :)
Reply to New consumer unit, builder says upgrade supply in the UK Electrical Forum area at ElectriciansForums.net
Thanks DefyG. I am thinking along those lines insofar as I will ask the electrician to build the DB/CU (plastic if he is OK with that)...
