New Consumer Unit on a TT System | on ElectriciansForums
Discuss New Consumer Unit on a TT System in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
brynmor
Am I right in saying the Regs for a TT system now say you can have DP main switch with all circuits on a 30mA RCD's (Split Board)?
yep. unless you can get the Zs values low enough to comply with disconnection times of the OCPDs. this is virtually impossible with a TT system.
Reply to New Consumer Unit on a TT System in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
462 excerpt below. The incoming supply is via a electrical plant room to the block of flat, each flat has a standard DNO cutout fuse but no...
