A customer has asked me to install a new ceramic hob to replace a gas one that requires it's own new circuit. After inspecting the DB a dual rcd model fitted about 3 years ago I noticed there were no stickers apart from an RCD one. No inspection dates and no old wiring stickers either. It seemed shabby as well and the DIN rail was visible through a missing slot cover.
After inspecting the wiring I noticed the 4 kitchen sockets were fed by a single 4 or 6mm radial circuit labelled cooker. I told her about this and suggested the new DB may not of been installed by a certified electrician because of this radial circuit. She said of course it was and that also the house had passed an inspection.
Anyway I priced a new surface mounted circuit, BUT if I suspect the DB has not been registered should I proceed with the work? On initial inspection there's not too much wrong with it apart form the missing slot cover and stickers and dodgy circuit. None of the circuit's are accurately labelled.
