New cooker circuit
Depends cooker size whether is 6 or 10mm cable ,bonding is in place , how long the cable runs are , access lifting floor board or through a loft surface or flush , cooker switch has sockets , RCD's on cdu ,
Realistically before anyone could realy price on this type of work they realy need to look at the property etc existing installation
or supply a little more info thanks
6mm, lifting up boards then trunking down, 10 meter run need rcd unit to come off old consumer unit.
and if it's 'old' probably needs earth and bonding doing too ??
Sounds like at least a half day, more if there's furniture to move or you've got to get through more than one room upstairs.
Realistically, only you can assess properly how long you think this job will take. Then simply work out the cost using your hourly rate.
