New drill, Makita or DeWalt? | on ElectriciansForums
Discuss New drill, Makita or DeWalt? in the Electrical Tools and Products area at ElectriciansForums.net
Paul.M
Supporter
Lost in Space
MY mate has the Makita and it is lasting well, he is a builder so it gets its share.
Personally I prefer Bosch for my corded drills.
Had a similar dewalt in 110 flavour. Only just gave up before Xmas after 8 years of drilling and chiselling. It was the core cutting that killed the clutch .... Oops.
Don't know about current dewalt quality compared to 8 years ago though...
That's the problem, My Bosch drills are ancient and have only had brushes and regular good clean outs.
I think the appearance of most new drills is flimsy in comparison.
bosch corded for me, the makita drill doesnt look as good quality.
get the professional one though with replaceable chuck
be careful with bosh though, they make a drill with a non standard chuck i think they call it the uneo or something, im not sure what drills they use that chuck on but you want an
sds+
That is similar to the one I have only mine is the older version without the variable speed. The one I have with the variable speed gave problems with the trigger and needed cleaning regular with electrical cleaning spray.
Both drills are brilliant though and can handle the 100mm core cutter. (hat on)
which spray? i use ipa myself and ill lol whenever people struggle with there drills because of crud etc.
i try to keep all my gear reasonably clean so they dont jam etc
Thanks for that, I will look later.
not the cheapest at maplin now ive looked
ÂŁ15 for 1L
[ElectriciansForums.net] New drill, Makita or DeWalt?
Reply to New drill, Makita or DeWalt? in the Electrical Tools and Products area at ElectriciansForums.net
Yet another vote for the biggest and the littlest. I use the big SDS solely for chasing (you still need it if you have a chaser as it doesn't get...
how often will you need to use it? Would renting one from a tool hire place be more cost effictive... and might give you an idea of good brands...
