New extension Kitchen appliances | on ElectriciansForums
Discuss New extension Kitchen appliances in the UK Electrical Forum area at ElectriciansForums.net
Hi all
I am in the middle of wiring my extension and just after some advice regarding the appliances.
I am thinking of running a radial to a double back box for grid switches for four appliances (freezer, washing machine, tumble dryer and fridge) and then having a sepearate kitchen ring.
Is this best option or can I have the appliances on the ring main too?
If you had the appliances on the grid switch that was fed by the ring final circuit then you would have make sure the grid switch was bang in the middle of the ring..I personally think having the grid on a ring final is bad design. What size radial was you thinking of running and what would the installation method be?
I was about to say the same...if you go on the averages of 500W freezer, 200W fridge, 2500W tumble dryer and 2000W washing machine when heating.....Thats about 22A. I don't like grid switches and would just install the appliance sockets in an adjacent cupboard. If you do want a grid switch then I would look at taking a couple of feeds to it.
Two separate circuits seems a lot of extra work just to have extra isolation points. Going to run the appliances on a dedicated 32A ring and then also have a kitchen ring.
Thanks for the help kingeri
Reply to New extension Kitchen appliances in the UK Electrical Forum area at ElectriciansForums.net
As an aside. I have seen patress/sockets fitted upside down under kitchen units with an appliance plugged in. The sockets were firm and not moving...
Thats why somebody told you to spk to the sparky
