- Joined
- Apr 10, 2015
- Messages
- 23
- Reaction score
- 7
My friend had a new fuseboard fitted I went to test it .unreal
Discuss New fuseboard fitted badly in the UK Electrical Forum area at ElectriciansForums.net
Not sure any of wagos lever connections can be used in MF situations only the push fits I believe, that situation wouldn’t need to be MF anyways would it? As the connection is easily accessible134.1.1 & 510.3 & 526.203 - Bet Wago haven't approved the product for such use
526.3.vi - Not MF in the current state
222's can be used MF, same box as the push fits. 221's also can be used MF, slightly different box though.Not sure any of wagos lever connections can be used in MF situations only the push fits I believe, that situation wouldn’t need to be MF anyways would it? As the connection is easily accessible
I agree... but I suspect that unless he had a suitable box/din rail etc. on the van... it would also have meant a trip to the wholesalers ? That might be an hour or so round trip... that's an hour of lost time... and maybe an hour late for his tea/a pint ?oh I agree , £65 on a din box and some decent din connectors and the job could have been so much neater
Just seen these on Amazon: https://www.amazon.co.uk/CTRICALVER...tor-Terminals/dp/B08PCRXXJT/ref=sr_1_32_sspa? and these: https://www.amazon.co.uk/dp/B08MFBZ...d_rd_w=sEMGT&pf_rd_p=6d92f084-6b53-4a72-8a21- I know when I first put the three core in line version on the forum I got all sorts of stick, so this is just for information I am not condoning them in any way or guaranteeing their use in any shape or form, these where the ones I got stick for: In Line Spring Lever Connectors 3 Pole 32A - https://www.toolstation.com/in-line-spring-lever-connectors/p78346
Only just learnt that wago is pronounced "var-go" and not "way-go"... definitely gonna stick with saying "way-go" now though... I've come too far to change my pronunciation of it!Not sure any of wagos lever connections can be used in MF situations only the push fits I believe, that situation wouldn’t need to be MF anyways would it? As the connection is easily accessible
Tel likes anything that makes life easier.Tel likes the third item.
Even Hager are guilty of that one. Obviously less of an issue with all RCBO boards now. Though it's the connections to the top of the RCD that are more of an issue - since in most cases the neutral bars aren't insulated anyway? (I think Chint do on some of their boards at least - and maybe Schneider too?)Used Chint consumer units many times before bought from an electrical wholesalers, not Screwfix, and find them to be decent.
The live and neutrals connecting the RCDs together and to the neutral bars are a solid conductor and not flexible which I much prefer.
The pre manufactured connections of flexible cores inside a new DB which show a lot of copper at the neutral bar connection are one of my pet peeves.
The Amazon ones look interesting - wonder what documentation there is to back up that they meet any standards though - are they copies of more well known brands?Just seen these on Amazon: CTRICALVER Terminal Set, Connecting Terminal Set with Lever, Wire Push Cable Connector, Compact Plug-in Terminals, 7 Pieces of 8-Pole Terminals,with Mounting Screws (2 in 6 Out): Amazon.co.uk: DIY & Tools - https://www.amazon.co.uk/CTRICALVER-Terminal-Connecting-Connector-Terminals/dp/B08PCRXXJT/ref=sr_1_32_sspa? and these: https://www.amazon.co.uk/dp/B08MFBZ...d_rd_w=sEMGT&pf_rd_p=6d92f084-6b53-4a72-8a21- I know when I first put the three core in line version on the forum I got all sorts of stick, so this is just for information I am not condoning them in any way or guaranteeing their use in any shape or form, these where the ones I got stick for: In Line Spring Lever Connectors 3 Pole 32A - https://www.toolstation.com/in-line-spring-lever-connectors/p78346
You can also buy adapters to use with the original Wago boxes - basically plastic spacers to fill in the extra space....222's can be used MF, same box as the push fits. 221's also can be used MF, slightly different box though.
Reply to New fuseboard fitted badly in the UK Electrical Forum area at ElectriciansForums.net
