new house 3phase heat pump | Page 4 | on ElectriciansForums
Discuss new house 3phase heat pump in the UK Electrical Forum area at ElectriciansForums.net
G
glasgospark
new house guys with a new heating system through mcs real scheme
3 phase supply run into house the pump is the only piece of equipment requiring 3phase ,
question is looking for best way to do this was thinking give the house itself the normal dual rcd db then from 3phase mains to lucy blocks fuse down for pump.
pump is situated in the same location as main cable head ,
4kw 32a 3phase supply required via rotary isolator
any views ?
Yes, but your only providing over current protection for the supply to the heat pump. As such, from the Henley block you take a 6mm2 for example to the switchfuse. The 32A fuses protect that cable from overload, the 100A fuses provide short circuit protection.
If you consider a busbar chamber, you wouldn't size everything fed from it to the size of the incomer.
You only require one point of isolation. This is primarily the cutout. I agree that one switch in front of everything is best, but only if the customer will pay!
Why would it be a 100A switch? You can get 32A switchfuses. Socomec make them among others.
[ElectriciansForums.net] new house 3phase heat pump
Reply to new house 3phase heat pump in the UK Electrical Forum area at ElectriciansForums.net
Your kWh figures are giving you consumption averaged over each hour period, but don't give an indication of total instantaneous current. To try...
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
