Those are the pictures from new hob. It require 6mm cable according to the plate info. Current hob is hardwired through 6mm cable too. Fuse at the fuseboard is 32A shared for oven and hob. Does it mean that fuse in the main fuseboard need replacing for 2x16A and then perhaps oven to be on a separate one? Just trying to get the idea of much extra work will be involved as I am contemplating whether is not easier to change the hob to the one that is compatible with current setup. Any advice would be much appreciated please. Thanks
