New insall in workshop and CU change in house advice | Page 2 | on ElectriciansForums
Discuss New insall in workshop and CU change in house advice in the UK Electrical Forum area at ElectriciansForums.net
PHS
Morning everyone,
I am looking for some advice and knowledge to help jog my memory as it’s been a few months since I finished my course and due to health reasons, I had to give up my job on site as a mate and start working for myself after 4 months off work.
This will be the first job I have had that lets me join a competent bodies scheme as they require a “big” job to come down and assess.
Basically, a fella has had a workshop built in the garden and wants it powered up and the old consumer unit in the house is extremely outdated and will be replaced too.
If you could please look over what I intend to do and pin point any mistakes or alterations that I may have over looked I would be most grateful.
The old CU in the house is fitted with B30 and B5 breakers from http://www.gepowercontrols.com
[ElectriciansForums.net] New insall in workshop and CU change in house advice
I would be looking at replacing this with a 11 Way Metal Consumer Unit-100 Amp Switch with a 63 Amp 30mA RCD 2 Pole-Wylex, Two 6 Amp Wylex MCB's, Three 32 Amp Wylex MCB's and a non protected 40 Amp Wylex MCB for run out to workshop.
30m run of 6mm SWA out to workshop and a 5 Way Metal Consumer Unit - 100 Amp Switch with a 40 Amp 30mA RCD 2 Pole - Wylex, One 6 Amp Wylex MCB running Two 2ft 18w Non Corrosive Weatherproof Fluorescent Light Fittings and Two 20 Amp Wylex MCB's on the Two radial circuits.
I would greatly appreciate any feedback on this set up as, although i have been a mate for 4 years and done the course, i'm still wet behind the ears after having so much time off work and not being around the industry for a few months now.
Many thanks in advance
i suppose i have to go get myself a Torque Setting VDE Screwdriver as well now too, seeing as its my test piece?
there was a lot of talk about them in the centre and i know there is mixed reviews as to the need for them
10 Way Hi Integrity Dual RCD + 100A Main Switch Consumer Unit
would i be better going for something like this then for the house CU?
with a 40 amp rcbo for run out to workshop?
The reason you are going for a High Integrity CU, is that you have an unprotected way (MCB) at the house CU. Otherwise you're not going to have any discrimination between the RCD device in the workshop CU and the RCD in the house CU!!! The SWA sub-main does not require RCD protection.....
Noted...
im gonna shoot down the wholesalers in a min to have a look at their boards anyway as theres no exploded views on any of the web pages.
I was always going for an unprotected mcb, just had the wrong type of cu in my first list
Fitted out the shed today, came across a small problem "I think"?
i have bought the WYNH506, 5 Way Metal Consumer Unit - 100 Amp Switch from TLC and need to know if I can put the 40amp RCD in it? I will need to cut the bar down to size and obviously wire it up to suit, it's only that, all the pictures and boards I have seen that have RCD in have more than the one neutral bar. Can instill fit the RCD in or do I need to swallow the cost and start again with the install with a new board???
it will be a pain as I have already installed all the conduit, sockets and lights.
Just as you think you've had a good day too lol.
Why didn't you consider the RCD before you bought the CU? What is at the other end of the supply to the shed?
I listed what I was putting in at the start of the thread and changed the house CU accordingly but didn't get any feedback about the 5 way board so thought it was ok. Learning about the boards is all trial and error and comes with experience as they don't tell you anything at all on any of the courses.
It all fits in the board (main switch, rcd, 2 20'sand a 6) it's just wether or not it can be wired up or not?
So the house board has a single RCD?
Reply to New insall in workshop and CU change in house advice in the UK Electrical Forum area at ElectriciansForums.net
He said something about a fused something as the lights hardly take anything .. I told him was mostly cordless tools so just chargers ..told him...
What is the distance from the point outside the house to the shed?
