New lamona cooker hood tripping both rcds | Page 2 | on ElectriciansForums
Discuss New lamona cooker hood tripping both rcds in the UK Electrical Forum area at ElectriciansForums.net
Prestatyn
Hi, installed a new lamona cooker hood as part of a kitchen refit. Connected to 6a lighting circuit on switched 3a fuse supply. All tested fine, but use any function on hood, and dual rcds trip. Checked wiring, all ok, fused switch is new click, but since not tripping when this is switched on, sure it’s not that. Fused switch as it’s own independent cabling. Before I remove extractor And frog march back to howdens, any one any constructive ideas?
It's a radial circuit with a 6amp OCPD.
If it offends then just label it on the CU as lighting and extractor fan.
On the 32amp ring final (oh the label just says 'sockets'.)
And there are a couple of FCUs on there, .
What am I to do??? Create another circuit labelled FCUs? Do me a favour.
Are we talking of Approved doc F?
Not all bathrooms require an extractor fan. I'm just in an argumentative frame of mind. I wouldn't put a cooker hood on a lighting circuit.
me neither. i'd put it on the wall above the cooker. :D:D:D
Of course, you do know that connecting directly to the consumer constitutes a new circuit??
This work therefore needs to be notified to the local authority, and of course you'll be providing an installation certificate that confirms that all of the tests you have done meets the requirements of BS7671?
Of course you will:rolleyes:
Ah, the extractor circuit already existed off the 6a mcb feeding upstairs lights and was switched fuse 13a. I replaced the fused switch so only a minor cert and no part p, but as I was adding a new circuit to electric hob on a 32a 4mm feed, I produced a major, and part p, included a whole plethora of minor changes on the back of the major. Part p completed as part of the condition report that was submitted by other spark. Not sure if neutral was mis connected already or by either of us when Completing tests. Paperwork is ridiculous though, takes nearly as long as finding the borrowed N!
I see the confusion but, as he says, it's connected to the lighting circuit.
Isn't a circuit defined as electrical equipment connected to the same OCPD??
Reply to New lamona cooker hood tripping both rcds in the UK Electrical Forum area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
