H
Hargen
Hi have just changed an existing ceiling light which had a transformer 240 - 12v with one very similar, just the output was different. I switched on for the first time and the new light started off dim then brightened and then dimmed again.
I removed the light to check that I was getting 240 across the live and neutral - (tested with the earth) and that was ok, so I checked the continuity as the light has a quick plug and I then noticed that the Earth and Neutral were making a circuit even out of the terminal block. Now i do not understand enough about the Ring main to understand if this is correct but i suspected it was not, but also why would it no be different to before?
Any assistance would be great.
