new lights | on ElectriciansForums
Discuss new lights in the UK Electrical Forum area at ElectriciansForums.net
s.keech
Hi I have 2 lights running from 1 switch, the power is going directly into switch then onto lights using the neutrals joined behind switch method.can I now take power from this using a junction box to new lights using loop method or do I have to join neutrals in new switch? thanks
Do you mean can you extend the circuit form the existing switch? If so then you can use the loop method or go to the new switch with the perm live and neutral and then to your new light.
I may have not understood your question, Im a bit confused about the junction box.
Reply to new lights in the UK Electrical Forum area at ElectriciansForums.net
Ouch. Danger notice to customer in my book.
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
