New member, straight in with a question | Page 2 | on ElectriciansForums
Discuss New member, straight in with a question in the The Welcome Forum area at ElectriciansForums.net
In truth,to accurately guage the size and type,there are many other factors to be considered,not least,installation earthing,duty cycles,fuelling and noise...
Just considering the possible running load,would only ensure reliability,for a day :)
If the genny is powering 3 motors, that "are pulling about 61a" each, how are the motors controlled (DOL, inverter) and do they all start at the same time?
Would you not need a bigger genny for the start-up of the motors?
Sorry spoon, I was given the wrong info, the power is for heating not motor and I can get them switched on and off individually via separate controls.
I appreciate that there is more to it. This is for film production purposes so will only be there a week so not really a problem if we overkill it with a bigger genny then needed.
I have got a 200kva that supplies 250a each phase so I'm going to suggest using just three of the 3 phase 63a heaters as although the Kva rating is ok, we will be pushing about 183a down each phase from my calcs
Reply to New member, straight in with a question in the The Welcome Forum area at ElectriciansForums.net
Gents has anyone done an application using the UKPN smart connect portal for a split phase supply and addition of multiple single phase battery...
When I was on the electric board We had a pair of pillocks connect a housing estate to a very large genset, the n lead was in two parts and not...
4K
