New one on me | on ElectriciansForums
Discuss New one on me in the Electrical Engineering Chat area at ElectriciansForums.net
Stopckport
Was called to a lighting fault yesterday, the lounge light would sometimes switch off when another light was switched on, easy I thought a loose feed in a switch or ceiling rose checked connections all okay problem persisted turned my attention to the lamps all were compact fluos except the lounge which was a vintage LED on closer examination when the lounge light went out I still had 230v at the rose and lampholder changed the LED for a compact fluo and the issue was solved. anybody else had similar incompatibility problems with LED?
Induced voltage from other circuits, common problem with older LED lamps, most modern LED lamps have snubbers fitted to avoid this.
Reply to New one on me in the Electrical Engineering Chat area at ElectriciansForums.net
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
