Does anyone no of companies that will manufacture our new patented electrical outlet that will make installing cookers and ovens are far easier job for all concerned.
Regards
Michael
Regards
Michael
Yes meeting with a couple of them at ELEX in Harrogate at the end of AprilHave you tried the normal companies? Hager, proteus, MK, click, BG?
To be frank, installing a cooker or oven is a once in a while job.
It’s not a portable appliance that gets unplugged time and time again.
Is your design a plug and socket combination?
Thanks yes just sent them an email cheers
A quick search brings up THIS and THISDo you have more info about your product? Presumably you should be OK sharing a brief description, since it is protected now.
Always interested to hear new ideas.
It's not a cooker switch. It's an outlet plate with a combined 13 amp socket. Could be useful when connecting a hob and oven to the same outlet.
Yeah but if you use a traditional cooker control unit along with a cable outlet further down the wall then you have means of isolation. With this you don't have that. So what's the advantage?
Cooker outlet plates have never had a built in means of isolation. That would be provided by the cooker switch above the worktop.
The outlet plate goes below the worktop.
Not much other than not having to wire the socket from the outlet plate. (Which is a pain in 6mm²)I know, but what does this offer over a dual back box with an outlet plate and socket fitted in it?
I suppose it comes down to how much it costs really. It can't be priced at much more than the cost of a single socket and an outlet plate.
Surface clipped cable isn't going to fly with many owners of a new kitchen.
I think it might be intended to be mounted lower down like where a flex outlet would be. But fed from an isolator switch above.
Cord grip is raised above plate level, so I suspect a cover is to be placed over it.
The inclusion of a 13A socket outlet led me to believe this was intended to replace the old fashioned cooker isolator/socket combo, but perhaps it is intended for used behind oven or below hob, with socket provided for gas igniter or microwave as previously suggested.
I need to get hold of a better imagination.
Like I saidI think it might be intended to be mounted lower down like where a flex outlet would be. But fed from an isolator switch above.
Like I said
Like I said
If retrofitting an oven and a hob most likely will find there is only a 1 gang box there at present. The dual cooker connection units I find are great to work with
Short length of flex and a trailing socket. Quite a lot of ovens I find wouldn't have enough room for a single socket and a plugUnless one item needs fusing down.
As mentioned above what we really need are lower profile higher current sockets and plugs for internal use.
The jump from 13A to 16A commando in terms of physical size is just silly!
They are still in fact available. BS546 is still a current standard!Back to the round pin 15A plugs maybe? They were ahead of their time!
Depends on what type of patent you have etc. if its not a bad idea... sell the Patent and walk off into the sunset . But if it is the outlet shown in the thread? If its any good , The Chinese will be all over it . "patents " mean nothing there . The cost to fully patent things costs a fortune .I owned a full patent that was established after 2 years .It cost £5k almost to the pound in 1992. I Then sold the full rights for £22k . I knew I could never fund the concept . But someone would want it and they did . And for them it was peanuts . Not a bad profit .Purchased a 20v Audi "UR" with the money !Does anyone no of companies that will manufacture our new patented electrical outlet that will make installing cookers and ovens are far easier job for all concerned.
Regards
Michael
A lot of that is to do with IP considerations, more than rating. A company called Neutrik attempted to take that problem on with a range of connectors that are IPx5 16-32A and literally about the size of a fat thumb but they've only ever really caught on in the events world, and even then only as final connectors. Power - https://www.neutrik.com/en/products/powerAs mentioned above what we really need are lower profile higher current sockets and plugs for internal use.
