erm right, so I've just gone and critiqued the new performance estimates and shading estimates methods in a comment on Martin Cotterells blog on solar power portal, and am now feeling slightly vulnerable for having stuck my neck out on there.
If anyone is thinking similar things about the performance estimates requirements, I'd appreciate it if you'd also stick a comment on there so I'm not seeming like so much of a long voice (it helps that the head of the solar design company has also written a guest blog saying much the same things, but some more installer input might help to get this changed before we're all forced to conduct complex additional performance estimates that are much less accurate than the estimates produced either via the method we use, or via the likes of PVSOL.
In the interim, the change I'd like to see made is for performance estimates made using more accurate methods approved by the MCS inspectors, to be allowed to be used instead of the MCS method.
ie that the MCS method becomes an absolute minimum standard, but methods that are more accurate are allowed to be used instead.
