New Shower Circuit | Page 2 | on ElectriciansForums
Discuss New Shower Circuit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
isn't that reserved for HM prisons, so they can do 100 prisoners at once without anyone having to bend down for the soap?
buried in plaster is classed as ref c so maybe its not clipped direct.
Just as long as it's not a long run, doesn't pass through insulation, isn't bunched or taken through oval conduit, then yes, buried in plaster is fine.
Still find it hard to believe that the manufacturers instructions would stipulate 10mm with a 50A OCPD...
Well whatever it is its fine as comes under clipped direct... Installation method is only thing can change this. Unless its a really long run but 40m is ok
Reply to New Shower Circuit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
And fully tested it with an MFT obviously
