New smart meter, storage heaters now trip RCD | Page 3 | on ElectriciansForums
Discuss New smart meter, storage heaters now trip RCD in the UK Electrical Forum area at ElectriciansForums.net
Brian N
nr34 0ln
I have just had a "smart" meter installed , and at night the electrics trips the RCD when the night storage radiator section comes on. I have had them out and they said installation was correct. I know a little about electrics (more over cautious and basic) but was suppressed when I looked at the lay out for the Night storage CU that the neutral goes through the RCD but the live goes direct - could this be a cause for the RCD to be triggered. I will have to get an electrician out to check all the wiring for the storage heaters if I cannot persuade them they have done something to suddenly make my electrics trip when that CU is on. Everything else seems to work fine. I have attached a simplified circuit diagram - electrics in the house have always been a little spaghetti junction, but never had any problems. Local electrician has always installed new stuff properly. Can anyone help? or suggest what my problem could be.
If I turn the CU for the night storage radiators off - then I get electrics 24/7 - if I turn that batch on then it pops overnight.
  • [ElectriciansForums.net] New smart meter, storage heaters now trip RCD
I did explain to the Manager of the complaints lot that it seemed very strange they would not come out until my electrics had gone off two days in a row - he said he would look into that policy, as he agreed that seemed wrong. I pointed out that if it appeared that the wiring may be at fault then they should have an electrician who could come out and double check the wiring- as clearly I had 3 people out - the first failed to wire it correctly and the following two had no idea about electrics. I doubt anything will change - still I should be able to buy a good amount of wine even after paying my electrician friend for doing the rewire - especially as I removed a wasp nest for him a few years back.
I went up into a loft on a new build once when the plumber was testing his newly installed heating system. Vent pipe over the header tank was gushing full bore, and splashing water everywhere.
Had to take a sheet of cardboard and a black marker pen, and draw out for him how he should have connected the tank. Pretty sure he didn't understand a word I said, but he changed it to my diagram anyway.
Reply to New smart meter, storage heaters now trip RCD in the UK Electrical Forum area at ElectriciansForums.net
Thank you to littlespark for clarifying my mumbo jumbo. Just to say that being on a dual tariff means you will typically pay more for electricity...
Interesting what you say, I have allowed with my system for the change to be half hour out, so start charging at 0:30 and stop at 7:30 but night...
