New stables behind house/garage | Page 3 | on ElectriciansForums
Discuss New stables behind house/garage in the UK Electrical Forum area at ElectriciansForums.net
Hi Ive been asked to fit some lights and a socket in a new stable yet to be built but its giving me a bit of a head ache. I haven't done a stable before so i just want to check with people in the know whats the best way of going about it. First of all there will be two stables sited in a paddock behind the customers house. They will sit directly behind a garage which will be converted to a tack room and storage room. The garage already has a supply fed by 2.5 SWA direct from the house CU (RCD protected side) on a 16A MCB. They have used a 16A because the run starts off as 2.5mm T&E buried in plaster and joins the 2.5mm SWA somewhere in the house. (This derates cable to 18.5A according to BGB) The garage has two strip lights and 4 double metalclad sockets on a ring. The house supply is TNC-S and is a good 25meteres maybe more from the garage. I measured the voltage in the garage and it was 239v, i checked the EFLI at a socket in the garage and i got 1.23ohms.
They want a light in each stable, a light in front of each stable, an outdoor socket near to them and the lights in the garage reconfiguring to accommodate the new layout. Im told the socket outside is for clippers and the sockets inside the garage will be for radio, battery charger or the like. Nothing major although they want an electric garage door at some point.
I cant see the load going over 16A at the moment although you never know in the future, They want to keep existing cable as its run underground and not easy to to run a new one to the stable, in fact it would be a real nightmare! I want to put a mini CU in the garage then have a DP main switch, two MCBs one for lights and one for sockets but this is where my problems begin, First of all i dont like it all being run off the RCD side of CU because if theres a fault in the garage or stable the whole house trips (although this is how it is set up now), secondly i can put a 6A MCB for lights but i cant put a 16A MCB for for sockets as there is already one at the other end. I thought about putting a 16A RCBO in the CU so at least if it tripped the rest of the house would be ok but what about the MCBs in garage?. The cable runs in the stable would be in plastic conduit and not near the horses i.e. up high and run outside. The customer wants to keep existing sockets in garage but they are just T&E clipped to the wall and i dont think they would last 5 minutes when the rats find them! I suggested just having a couple of sockets and changing to conduit. I'm also a bit worried about volt drop as its a long way to go in 2.5mm when you add on the circuits in garage and stables. My calculations dont add up to the 239volts i measured. It would all be protected by 30mA RCD or RCBO.
Any help and advise would be gratefully appreciated as its doing my head in trying to figure what to do for the best. If i could i would just run a new SWA cable from a new board but as i said its not really an option it involves going over a neighbors property, digging up landscaped gardens etc etc etc
Cheers in advance
Michael
its worth the risk for a highways dept , closing 1 mile of 1 lane of motorway costs several grand a day so a massive saving of tens of '000s.
me and my boss "observed" while the company operator demo'd the equipment , not knowing he was saving us a 3 day manual dig lol
A directional drill is the next one on my wish list , but at £15,000 for even a knacked at the end of its life one , i think it will be on the list for a bit yet !:bigcry:
Yard up the road from me lost 4 horses in one instance,drinkers in four seperate stables providing the input...Sounds like the customer has been given too much room to impart rules,if they don't like cable install costs,they are going to hate cost of new TD 300Ma rcd etc...Recommend they swap to hamsters...
Ive found recently that in life it's those that have little money are the most generous!
I can't (well I suppose I can) believe that a customer that can afford horses doesn't want to pay to have a job done properly! As others have said, price it properly, explain the reasoning and if required walk (trot) away.
At the end of the day all you can do is quote for the job (properly done) and leave it in their hands. If they don't want to do it then walk away, I wouldn't get involved in doing work I know to be crap.
Thanks for advice and comments, quote went in to customer with a full explanation and they said what with cost of stables they will leave the electrics for now! As mentioned in comments earlier they do have a few quid, i know brand new range rovers aren't cheap nor are 6 bed houses in private streets. I guess they just feel they are getting value for money with a nice new stable block but not with a few lights and sockets. Thanks again ill keep at it!
Michael
Michael
Best thing about theses threads is the ability to learn for the next time.
If I were you I'd be working out an approx price for the job, so next time you are looking at something similar, you can "bounce" an approx price off the customer when you visit them and you can watch their reaction!
Reply to New stables behind house/garage in the UK Electrical Forum area at ElectriciansForums.net
Haha yes, it is. Must be a northern expression. Have a Google 😂
