steviethespark
Ok guys im wiring a house atm and was wondering if this set up met regulations ?i have a meter cubicle installed at the side of my garage were nie supply enters ,from there i have a set of 16mm double insulated tails feeding a set of iscos inside of garage located beside garage db ,from there i will install a 80ma time delayed trip feed from iscos using 16mm double insulated tails and 1 way incloseure ,the under ground cable i propose to use is 16mm split in 4inch sewer duct piped 30m to main house ,once entered the house will be installing 2 no 16 way hager db ,all circuits will be distributed between 4 x30ma 80a rcds with exception of smoke dection and alarm system ,the 16mm split may have to terminate into main 80a isolator and 2nd 16 way db will be fead from a 63 a mcb on same board ,hope this makes sense guys ?
