New supply to new build
I was covering the sub mains because the cable will be live from a very early stage and there will be quite a bit of digging around it for sewers ect at a later date
It's a few years since I last worked on a new build house, but when I did they always completed that kind of ground works a lot earlier in the job than the point when we started livening up the circuits. We only had the temp supply board live at that time.
And if it's being buried then split con doesn't comply as it doesn't have a complete earthed metallic layer,
U might want to check that because split does comply
check what? you want to feed a new board with a cable that has an RCD at the front of it...........
edit: just realised the quoted is on about split concentric cable lol
steviethespark,
Simonslimline,
