B
brizospark
We have been involved in the installation of a dust extraction system which is powered by a fairly large 3 phase motor (18A).
The motor was pre-wire to a control box on the side of the extraction housing and the star/delta starter was also pre-wired. The only wiring that was required was the 2 sets of cables from the extraction junction box to the star delta starter. These cables were to be connected to the main contactor and the star contactor, anyway we followed the drawing to a t.
The overload was set at 22a and we have used a 32 TP type C MCB at the DB.
The motor was first operated yesterday, it ran for a few hours and then the MCB tripped. I couldn't understand why this would trip before the O/L but anyway it did.
So I had a look at the motor and it was red hot, couldn't even touch it for any period of time so we waited a bit and checked everything, our wiring was spot to drawing and everything in the starter looked ok. I took the cover off the motor when it was cool enough and checked the resistance across the set of windings and one set was Open circuit.
Any ideas what could have caused this apart from a faulty motor?
To be honest RoB if the OP can’t provide the required information then we may as well wash our hands of it. I can’t see a way forward with what we have.
To the OP:
If this is a turnkey project get the machine manufacturer in and stop wasting everyone’s time.
Generally if all settings are correct an overload trip points to a mechanical problem, and a MCB trip points to an electrical problem. Does it have to be star/delta start, I would have thought a fan even up to this size it could be DOL.
New three phase motor winding burn out
brizospark,
pepparz,
