New, to me, lighting wiring | on ElectriciansForums
Discuss New, to me, lighting wiring in the UK Electrical Forum area at ElectriciansForums.net
GBDamo
UK
Replacing some 6' fluorescents with LED panels in newly installed suspended ceiling.
Expecting to find most of the fittings wired loop in - loop out and one fitting with switched live.
However to my surprise I found the wiring as above but there was also two double sheathed single lives terminating at the fitting with the lives in the T&E linked.
The initial install was 1974, before my time, so if any of the dinosaurs can give me a few pointers as to whats going on would be appreciated.
Not quite understanding what you mean.
Are the extra cable single-and-earth? (6241Y)
Is it the looped live? Back then it mould be the norm. Allowing neutral joints in the switch is fairly new
Can you draw a diagram?
No, just single lives but double sheathed ( insulated and sheathed 6181Y)
I think it is the switched but without belling it out..???
[ElectriciansForums.net] New, to me, lighting wiring
I am no artist.
To me your work of art says two supplies. Either two switched supplies or a permanent live for some reason. Are the T&Es connected to any of the lights or do they all just bypass the fittings and are they actually live.
Reply to New, to me, lighting wiring in the UK Electrical Forum area at ElectriciansForums.net
Thank you so much for your help with this light work perfect now thank you again much appreciated
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
