New to PAT. Everything fails | Page 2 | on ElectriciansForums
Discuss New to PAT. Everything fails in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
You need to have done you PAT testing cert' or be under the instruction of someone that has done it to be able to issue PAT test sheets, the course requires you to have a book that explains all this and maybe part of the exam (random generated questions). If you dont have the correct cert's and someone had a accident with something you passed then you wont have a leg to stand on legally.
Where does it say that then ? :shocked3:
I suspect there is no actual requirement, you just need to perhaps demonstrate competence in the event of a court case.
Yep, of which a certificate such as 2377 or similar will do :) Also if anyone does have an accident, there is the getout that it was working fine when you tested it, and that it's safety was only guaranteed at that point.
true enough.
I just was concerned the inference was that, that was the only way! Which it isn't.
I don't PAT test btw. I choose not to!
Earth bond, Fridges copper pipe or the filter drier the bullet shaped thing round the back, irons if teflon coated wriggle the clamp during test,it'll spark like hell but you get a result,
Pict
It sounds like the only appliance that passed had no on or off switch. Don't forget that the appliance has to be in the "on" position to get a reading.
no but the line does . your PAT tester is measuring the R1+R2 of the appliance so there must be a loop, line/cpc.
Sorry swordfish - typo error, and I missed the apostrophe - black star for the wall chart eh!
What is it that "kind of makes a loop"?
I'm a bit puzzled, I thought earth bond test was to find an acceptable resistance reading from earth pin on plug of appliance to its casing (being Class I, that is).
Markie have got the Metrel Betapat Plus what is the easiest way to understand codes i am new to this (am not a sparks) but have passed G AND G finding it difficult to match codes to appliances
Reply to New to PAT. Everything fails in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
out of interest UK, how do you know what kit is connected?
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
